el 10-28-2013 04:09 AM
No consigo ver una camara AXIS desde una cRIO 9082, ademas en el MAX aparece el VISA error
0xBFFF00A7 (VI_ERROR_MACHINE_NAVAIL)
viFindRsrc returned 0xBFFF00A7 (The remote machine does not exist or is not accepting any connections. If the NI-VISA server is installed and running on the remote machine, it might have an incompatible version or might be listening on a different port.)
Please make sure the VISA server is running on the remote machine at the correct port and that both this machine and the remote machine are plugged into the network.
Possible causes for this error:
1. The remote machine name may be incorrectly specified (either the name was misspelled or the wrong IP address was typed in).
2. The remote machine may not be turned on.
3. Either the local machine or the remote machine is not connected to the network.
4. There is a network configuration problem, such as an improperly assigned IP address, an incorrectly configured routing table, or a firewall between the local and remote machine.
5. The VISA server is running on a different port on the remote machine than what you have set for the remote machine in this computer's VISA Options remote tab.
6. The VISA server was started but is either suspended or is no longer running on the remote machine.
el 10-28-2013 05:33 PM
Estimado
Prueba cambiarle la IP a tu cRIO de acuerdo a la red en la que estes. Si estas en una conexion punto a punto entonces resetea al cRIO para que quede en DHCP y obtenga la IP default, la cual deberia ser 169.254.x.x segun lo que indica el manual.
Si al resetear no encuentras tu target en Max pudes ver la IP con el NI network browser.
Saludos
