el 05-29-2007 05:03 AM
el 05-29-2007 10:33 AM
Hi Xchiquete!
This problem is most likely related to a driver you updated recently or a driver that you are including, i.e. daqmx, and it's not being correctly included. Try the following and check if it works for you, i included some links to related cases which may also help you, hope it all goes well 🙂
1. Delete the "Application" folder which was created after the unsuccessful builds.
2. Uncach the folder in the Build Specs
3. Copy your driver CDs to your hard driver and point to the newly created folder
http://forums.ni.com/ni/board/message?board.id=250&message.id=29940&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=244845&query.id=526126#M244845
http://forums.ni.com/ni/board/message?board.id=170&message.id=214393&requireLogin=False
Oswald Branford
