cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
How I connect PCI-FBUS/2 with FF basic device?
¡Resuelto!
Ir a solución
I have a PCI -FBUS/2 and FF actuator of valve. I need to make a simple test for communication between FF actuator and PCI-FBUS & FBUS CONFIGURATOR Software.
How I connect the pin 6 and 7 of DB-9 port in PCI-FBUS/2 with basic Device and power supply (24 VDC) of bus?
0 kudos
Mensaje 1 de 2
3.032 Vistas
Solución
Aceptado por el autor del tema jaime3008
Jaime -
To learn how to test your instalation you should see the Getting Started with PCI FBUS (see the link below). There you will find step by step instructions to learn how to test your instalation.
http://digital.ni.com/manuals.nsf/websearch/0E6E078004675CDB86256D28005BD47A
Pin conection, however, depends on your power supply.
I hope this helps.
Merry Christmas and a happy New Year
Bruno Noronha
Certified LabVIEW Associate Developer
Using LabVIEW 8.6
0 kudos
Mensaje 2 de 2
3.013 Vistas
