01-17-2009 08:48 AM - editado 01-17-2009 08:49 AM
Hello everybody,
I'm building a CVI application. I need some functions of LabView (related to time series analysis), so I'm trying to build DLLs with the .VIs I need. I followed all the steps necesary and visited all the related topics at ni.com. I always get the following error:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. +¡
Use the following information as a reference: Error -2147221480 occurred at Building DLL stub.
This can be caused by illegal function or parameter names. Please verify your names are legal C identifiers and do not conflict with LabVIEW headers
This error code is undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code input.
Once, I got a correct DLL with no errors, so it should be possible for others.
This is an example of what I'm trying to compile:
And this is what appears, only for a moment, at the end of the compiling (it didn't appear when I manage to build with no errors):
I'm using: LabView 8.2, LabWindows CVI 8.5, NI-DAQ 8.5, Windows XP (SP2)
Any suggestion is really appreciated.
Maybe another way to use this functions in CVI (I need functions related to spectral estimation, ARMA; MUSIC,...)
thank you!
Eduardo Tamargo
Spain
el 01-19-2009 02:33 AM
Hi Tamargo,
This is exactly the same post as this one. Please let's try to keep just one post for the same issue. Thanks.
