Error 58 when trying to run bluetooth examples on LabView8, server and client
Hi there... I´m really new to LabView and just downloaded the 8.0 version for trial. I tryied to run the simple server and simple client examples for bluetooth on LabView 8 and it keeps giving me error 58 (Error 58 occurred at Bluetooth Create Listener in Simple Bluetooth Server.vi) and the supossed reason is: Possible reason(s): LabVIEW:  The network function is not supported by the system. I´m using Win XP home... Can enybody tell me how to solve this problem..?
(8,946 Views)
Hi carosamu!
First of all, we need to know if you have the basic requeriments regarding your OS, this is a tutorial, where you can find this information, and contains links to Knowledge Bases from Microsoft, to get the correct drivers. Also you can find the basic information on basic bluetooth functions.
http://zone.ni.com/devzone/conceptd.nsf/webmain/5EB9312A6470F16A86256E7500726F15?opendocument
Hola carosamu,
Primero debemos verificar que tengamos los requerimientos mínimos en cuanto al Sistema Operativo, en este tutorial, podemos encontrar esta información, y contiene enlaces a Bases de conocimiento de Microsoft, para obtener los drivers correctos. Tambien el tutorial, tiene información básica sobre la funciones básicas de Bluetooth.
Tania Lozoya
(8,888 Views)
