el 01-23-2020 09:09 AM
Hola
Es posible cambiar los valores del enum? Es decir, cuando defines el item que puedas asignarle tu el valor que quieres
¡Resuelto! Ir a solución.
el 01-23-2020 09:12 AM
Hi 99,
you already know this is an English speaking forum!?
Is it possible to change the values of the enum? That is, when you define the item you can assign the value you want to
In an enum the values are simply ordered, the "value" is the item text. The "number" is just the index inside the enum item list.
When you want to use arbitrary values associated with texts then you should use a ring instead…
el 01-23-2020 09:15 AM
LabVIEW99,
If you want to post a message in Spanish, go to the Spanish forum that is under Regional Communities. I know I have mentioned this to you before.
Your message thread as been moved there.
If you are able to speak English, than go ahead and post in the English-speaking LabVIEW forum. There are far more English speakers so you are more likely to get help quicker.
el 01-23-2020 09:29 AM
Programaticamente no, pero el Ring control sí.
el 01-24-2020 02:25 AM
I´m so sorry,
But if I use ring control I have the same problem. Because I want for exam`ple to put one name to the item and assign the number 8. I mean, for example, RESET and in the column of values put the number 8 no number 0. I hope I have explained myself better.
01-24-2020 02:44 AM - editado 01-24-2020 02:44 AM
Hi 99,
what's your problem?
el 01-24-2020 03:31 AM
I wasn´t disabling the option you have marked,sorry.
Thank you so much for your help!
Best regards
el 01-24-2020 07:17 AM
I have found one problem. When I connect the ring to the case structure I can´t see all the cases
01-24-2020 07:37 AM - editado 01-24-2020 07:38 AM
el 01-27-2020 02:44 AM
I have done what you said but I continue without seeing all the cases. I attach you the program.
