08-03-2021 03:54 PM
Hello, I need help imaging one of our roborios.
I can change the firmware from 6.0.0f1 to 5.0.0f1 and back to 6.0.0f1 but every time I try to reimage the OS, it fails after about 10 minutes with a "Unable to download image to target" Error.
I have tried with images:
FRC_roboRIO_2021_v3.0.zip
FRC_roboRIO_2021_v1.0.zip
FRC_roboRIO_2020_v10.0.zip
FRC_roboRIO_2018_v16.0.zip
and they all give the same error.
I power cycle and it always comes back up to 3 blinking status light sequence, it always comes back to safe mode after a power cycle, even when I don't try to make it go into safe mode.
It currently reports image version FRC_roboRIO_2015v23
Please send me a fix if you can, thanks.
08-08-2021 09:14 PM
Solved. Mshafer helped me.
What I noticed was that the triple flash became a double flash after using the rescue image.
I think the double flash means at that point that the rescue put a V2 firmware (old) and says requires update in the normal tool.
the double flash also meant that no OS image was present, just firmware I believe.
I updated firmware to v6 and then put a 2021 v3 OS image on it and it now responds.
Thank you,
John
