Discovering and Imaging the Device
Roborio Cannot Image
There are three roborios in our team that cannot be imaged
P/N:155213F - 01L
S/N:313BB3C
P/N:155213D - 01L
S/N:306CDF5
P/N:155213F - 01L
S/N:3134CD2
Now we need help.Due to the firmware issue of version 2021 3.1,they all have the same problem, the only solution is to use the USB initial firmware reset
(2,824 Views)
Hi Richard,
Thanks for reaching out.
Before we try the USB reset/recovery method (because if that doesn't work only remaining option is to RMA the rio), can you attempt (or confirm that you've already attempted) using safe mode and the 3.0 version?
(details on safe mode here: https://docs.wpilib.org/en/stable/docs/software/roborio-info/recovering-a-roborio-using-safe-mode.ht...)
(2,782 Views)
I have tried this way,but I can not connect to roborio. The status light keeps flashing,only two lights are on.so I think that the usb method is the only way to fix them.
(2,772 Views)
Accepted by Richard1991
I sent an email to the address listed on your profile with the recovery file and instructions. Please report back (either via email or here on forums) and let me know if that works for you.
(2,754 Views)
it works.thank you so much.
(2,742 Views)
