06-01-2021 01:11 PM
Hi Robotheosis,
Couple of things we should try before the usb recovery method (since you shouldn't need the password to complete a firmware upgrade):
* Using the imaging tool (not MAX) to format and then update firmware on the target - https://docs.wpilib.org/en/stable/docs/zero-to-robot/step-3/imaging-your-roborio.html#imaging-the-ro...
* safe mode - https://docs.wpilib.org/en/stable/docs/software/roborio-info/recovering-a-roborio-using-safe-mode.ht...
Also, when you say the default password, you mean blank, right?
06-02-2021 09:30 AM
Hi, thanks for that. What's strange is in safe mode it's still asking for a password — I've tried multiple times. I have used the imaging tool, the problem is I can't image without updating firmware, the RoboRIO is so old (version 2-ish) and it says minimum version is 5.0-ish to reformat, so I'm sort of stuck. Need to update firmware but that asks for password, again even in safe mode.
By default I do mean blank yes. I've also done admin admin, root admin, admin password, all that basic stuff.
Thanks so much for your reply. This is a frustrating problem. Everyone on the team who was around during this RoboRIO's use is long gone.
06-02-2021 10:25 AM
I've emailed the recovery file (and instructions) to the email on your profile.
12-19-2021 05:26 PM
My roborio cannot be imaged too,the status light is blinking,can you send me the recovery file?
My e-mail: hexuguo@outlook.com
Thank you
01-18-2022 12:39 PM
hello, i have the same problem, can you help me?
01-18-2022 12:42 PM
First question, do you have the roborio1 or the roborio2?
01-18-2022 08:06 PM
Hi @mshafer!, we have the same problem with the roborio 1, can u help us?
01-19-2022 01:12 AM
Hi! We have the same problem with the roborio 1, @mshafer, can u help us?
01-19-2022 08:36 AM
@rashest, following up in direct message
01-19-2022
12:54 PM
- last edited on
01-19-2022
01:36 PM
by
NI_Community_Su
hello thanks for the reply. Robrio 2.0. I tried everything for 3 days, unfortunately it doesn't work.
Can you send me the recovery file? Or we will be very happy if you can contact us remotely and help us (using team viewer)
