Discovering and Imaging the Device
RoboRIO not imaging
Hi Robotheosis,
Couple of things we should try before the usb recovery method (since you shouldn't need the password to complete a firmware upgrade):
* Using the imaging tool (not MAX) to format and then update firmware on the target - https://docs.wpilib.org/en/stable/docs/zero-to-robot/step-3/imaging-your-roborio.html#imaging-the-ro...
* safe mode - https://docs.wpilib.org/en/stable/docs/software/roborio-info/recovering-a-roborio-using-safe-mode.ht...
Also, when you say the default password, you mean blank, right?
Message 11 of 23
(2,743 Views)
Hi, thanks for that. What's strange is in safe mode it's still asking for a password — I've tried multiple times. I have used the imaging tool, the problem is I can't image without updating firmware, the RoboRIO is so old (version 2-ish) and it says minimum version is 5.0-ish to reformat, so I'm sort of stuck. Need to update firmware but that asks for password, again even in safe mode.
By default I do mean blank yes. I've also done admin admin, root admin, admin password, all that basic stuff.
Thanks so much for your reply. This is a frustrating problem. Everyone on the team who was around during this RoboRIO's use is long gone.
Message 12 of 23
(2,738 Views)
I've emailed the recovery file (and instructions) to the email on your profile.
Message 13 of 23
(2,733 Views)
My roborio cannot be imaged too,the status light is blinking,can you send me the recovery file?
My e-mail: hexuguo@outlook.com
Thank you
Message 14 of 23
(1,984 Views)
hello, i have the same problem, can you help me?
Message 15 of 23
(1,903 Views)
First question, do you have the roborio1 or the roborio2?
Message 16 of 23
(1,900 Views)
Hi @mshafer!, we have the same problem with the roborio 1, can u help us?
Message 17 of 23
(1,874 Views)
Hi! We have the same problem with the roborio 1, @mshafer, can u help us?
Message 18 of 23
(1,885 Views)
@rashest, following up in direct message
Message 19 of 23
(1,871 Views)
hello thanks for the reply. Robrio 2.0. I tried everything for 3 days, unfortunately it doesn't work.
Can you send me the recovery file? Or we will be very happy if you can contact us remotely and help us (using team viewer)
Message 20 of 23
(1,841 Views)
