05-16-2021 06:36 PM
Imaging the roborio causes this issue. I have followed every step in this guide and asked people on discord with no luck. Trying to put new firmware on the roborio also gives an error. I believe I need a new USB image.
05-17-2021 03:02 PM - edited 05-17-2021 03:02 PM
Seeing as so many of us have this problem https://forums.ni.com/t5/Discovering-and-Imaging-the/Cannot-image-roboRIO/td-p/4150312 you'd think NI would make this an easier issue to fix. Here's to hoping we get help soon.
05-18-2021 08:19 AM
Hi KSpooky,
Just to confirm, are you able to get the roborio into safemode? If so, can you try to re-image it then?
(the reason we try the USB method as an absolute last resort is if it fails, there is no option but to RMA the roboRIO).
05-18-2021 10:26 AM
The roborio was in safe mode when I tried the steps above.
05-18-2021 10:48 AM
I sent you the recovery file and instructions (in a DM and using the email in your profile). Please let post back whether or not that works for you.
