le 02-04-2021 05:19 PM
P/N 155213D-01L
S/N 305cc55
MAC 00802F17A48B
During of updating a Rio from another team we were able update the firmware, but got this message when trying to format
Error -2147220335 occurred at 5.3vi2890001
Complete call chain
Nisyscfg.lvlib.format 5.3.vi.2890001
robotrioImagingTool.Lvlib.reconfig device.vi
Roborioimagingtool.lvlib.imagemangager.vi
roborioimagingtool.lvlib.imagingToolMain.vi
Status: Corrupt firmware Cannot run
We went through all of the steps from help with formatting document we found and the steps with the error message and get the same failure at the same point.
Résolu ! Accéder à la solution.
le 02-05-2021 10:54 AM
Which firmware are you trying to image to?
le 02-05-2021 10:59 AM
We were trying to update to the firmware 6.0.0.cfg
le 02-05-2021 11:00 AM
Also did not mention that the USB and ethernet seem to lose the connection during the process of updating the firmware or image, even if we get the message that the firmware was successfully installed.
le 02-05-2021 01:26 PM
Connections dropping is definitely problematic, are the ethernet and usb cables loose in their ports?
le 02-05-2021 01:44 PM
The connections are solid, and tried different cables and different computers. Occasionally using the Web tool its gets to a restarting point before failing.
le 02-05-2021 01:52 PM
Well about the only other thing I can think of to try is to do a usb recovery and see if that helps. I'll DM you details.
le 02-05-2021 01:58 PM
Are you losing the connection while the device is restarting? Or, during other periods? I'd echo the later remarks this is problematic if it's happening during other periods. I wouldn't be so worried about it while the device is restarting.
You've used a couple words that would make me want to seek clarity. You've said the firmware updates and gives a successful message. In the web interface, what version of the firmware does the device say it's running? Does it say 6.0.0 or something else?
You appear to be running into issues while using "format" which suggests during adding the new image rather than the firmware. Which image are you trying to use? Ideally, we'd see you working with 3.0. If you're using 3.1, you'll want to download and install the FRC Game Tools again before continuing further.
le 02-05-2021 02:07 PM
I have gotten errors at different points, depending on the tool, when using the standard roborio imaging tool, I get the sound as if the usb is disconnected, but it still says the firmware is uploaded successfully, but when trying to image it says the firmware is corrupt.
The web interface thinks that it is running a firmware of 6.0.0. As does the roborio imaging tool.
I am was attempting 3.0 but also tried the last version of 2019 v 10 I believe to see if anything would stick. Same error.
le 02-05-2021 02:21 PM
I was unable to DM you (I think you have it turned off in settings),
We should double check that your computer name has only letters and numbers in it (this is one of the steps in FRC Firmware Update Failing ) - Microsoft doc on seeing/changing this
Also, some teams have had success using firmware 5.0.0 - does that help any?
