Digital Multimeters (DMMs) and Precision DC Sources
... spurious TC (asynchronous) readings on NI4351 ...
Bjorn,
Thank you for posting to the NI Forums.  I am not sure if Matt is monitoring the forums, the post was several years ago but hopefully we can help you out.  Could you explain how you are getting the same issue?  Are you running several DAQ devices at the same time as in Matt's application? Could you provide a quick rundown of your hardware and software setup?  Are you programming the 4351 with the DAQ VIs or are you programming it with the 4351 software calls?
Neil S.
Message Edited by Neil S. on 08-24-2006 04:04 PM
Message 11 of 11
(3,687 Views)
