Digital Multimeters (DMMs) and Precision DC Sources
sine wave generation with smu
Thanks Marcos
 That is really professinal support, I got my answer
Message 21 of 23
(3,669 Views)
I would just like to know if the VI can be modified to output a signal with frequency higher than 5 kHz.
Or is the 5 kHz limitation due to the hardware capabilities of SMUs?
Thanks and Best Regards!
Message 22 of 23
(2,456 Views)
Heads up: this is now a first-class feature with new firmware added to the NI 414x SMUs, as well as the NI 4135->4139.  The feature is included in NI DCPower 18.2: http://www.ni.com/download/ni-dcpower-18.2/7859/en/ . The relevant attribute is "Sequence Step Delta Time", which as the name implies is a defined time between steps of a sequence reguardless of source delay or measure time.
A sine wave could be created by feeding in the waveform points and a constant "delta time", but for more complex waveforms you may adjust the time between points to provide finer resoltion during interesting parts of the waveform, such as a simulating the startup behavior of a power rail.  Check the SMU specifications for minimum delta times and resolutions, they very slightly by product.
Happy waveforming
Message 23 of 23
(1,895 Views)
