Digital Multimeters (DMMs) and Precision DC Sources
keithley 2400 ramping buffer read
I'm struggling at the moment with the attached VI using LabView 8.2, a Keithley 2400 Sourcemeter with a Keithley KUSB-488 USB-GPIB adapter. I want to run different ramping voltages (at the moment only linear ramping is programmed) measuring current. When I'm starting the program I get two error messages from the 2400 (-201, -420), then the voltage is properly ramped but the buffer is not read and I got a timeout error from "Wait for RQS". The funny thing is when I'm running an example program from Labview and then run my VI afterwards the currents can be read. When I now add a while loop between the VISA Event Icons I can read the currents one time but then I'm getting the timeout error again...
I want to stay with the VISA programming (and not with the 24xx-driver pallette) because this is only a small part of a bigger, more flexible program including more instruments.
I think I've done somethin wrong with either the instrument commands or the sequence for the buffer read...
I would be very thankful if someone can give some hints for my problem...thx.
Mike
Win XP, LabView 8.20
(8,184 Views)
Me again,
I've done some smaller, simpler VI with a while loop (please find attached). The also attached sceen is from NI-Spy doing the while loop three times...also the errors on the 2400 (-201, -420) are still there but when I'm running the program the second time (without restarting the 2400) they do not show up.
So, if someone has an idea...
Mike
(8,179 Views)
OK, have fixed the loop problem...very stupid mistake, forgot to enable buffer tracing...grrrr.
But still have those irritating errors from the Keithley 2400 but for that I will contact Keithley...
Mike
(8,173 Views)
