Digital Multimeters (DMMs) and Precision DC Sources
keithley 2000 dmm software
I have a keithley 2000 dmm but I don't have Labview and so I can't interface it with my computer. Does anyone know of any software that will work with this multimeter on windows xp/7?
Many thanks
(8,993 Views)
C, C++, Visual Basic, .NET, Java, Pascal, etc. In other words, just about any programming language you want to use. There is an IVI driver so you can use that with different languages. If you are going to use a GPIB board, you'll also have to make sure there is language support for that.
p.s. You posted to the wrong board. This is for NI DMM's. Post new questions to the Instrument Control board.
(8,992 Views)
Hi all,
Thank you for contacting National Instruments. If you decide that you want to use LabVIEW to control this instrument, I have attached a link to the driver that you can use to control this instrument.
If you want a bespoke piece of software that will simply control the instrument without you requiring to do any programming then I would recommend the NI Alliance channel. They will be able to write a piece of software that can control this device.
Failing that, I would suggest contacting Keithley and enquiring about software.
I hope this helps.
Andrew McLennan
(8,970 Views)
