Digital Multimeters (DMMs) and Precision DC Sources
Using a budget pocket DMM alongside bench instruments practical experience with the MAS830L
Hi all, wanted to share some field experience using the Mastech MAS830L as a secondary/quick-check DMM in a lab and prototyping context and get the community's thoughts on how you handle bench vs pocket meter workflows.
We often use a bench DMM for precision work, but during breadboard prototyping and field debugging, a lightweight pocket meter saves a lot of time. The MAS830L has been our go-to for that role. Key specs for context:
Parameter Spec
Display 1999 counts, 15mm backlit LCD (3½ digit)
DC Voltage accuracy ±0.5% (200mV–2V), ±0.8% (20V–600V)
DC Current range 200µA – 10A
Resistance 200Ω – 2MΩ
Safety rating CAT III 600V
Extra functions hFE transistor test, diode test, continuity buzzer, data hold
One thing worth noting: the dual-slope integration A/D converter makes readings stable even in noisy environments something I didn't expect at this price point. The continuity buzzer responds fast enough for quick wire tracing, and the data hold function is genuinely useful when probing tight spaces where you can't watch the display simultaneously.
Tip: When using the 10A current range, keep measurements brief (<15 sec) the MAS830L uses a single internal shunt without cooling, so extended high-current draws can affect accuracy and the fuse.
Curious does anyone here have a structured approach for cross-checking readings between a pocket meter and a bench reference? At what accuracy threshold do you decide a secondary meter is "good enough" for a given task?
(328 Views)
Question to ask yourself, do you need to measure and report to someone or just a sanity check for yourself, if sanity check, handheld DMM is fine.
Handheld DMM are fit for all good-enough jobs, like sanity check if there is a mains supply or the voltage is within the ballpark.
You need a lab-grade DMM, i.e., a bench DMM with higher digits, for anything that you want to rely on your numbers (like datasheet specs).
Santhosh
Soliton Technologies
Only two ways to appreciate someone who spent their free time to reply/answer your question - give them Kudos or mark their reply as the answer/solution
(318 Views)
We use Fluke handheld DMMs all the time. They are not so good for automation, but are good for getting quick readings and troubleshooting.
(301 Views)
Thanks, Santo, that’s a clear and practical way to look at it. I agree that a handheld DMM works well for quick checks, while a bench DMM makes sense when accuracy really matters. Appreciate you taking the time to explain this!
(270 Views)
