Hi Alaini,
Sorry I forgot to attach the photo, please see the image below. The area in red is where you will find the fuse of interest. I agree given the intermittancy of the problem the fuse may not be the culprit but I think it would be a good troubleshooting step since it should be fairly easy to check. Regarding the power outage, can you elaborate on this? If there was a power surge on the system due to lightning or something else, then I would say it's possible that something could have become damaged during that period. However, I think it's unlikely a simple removal of power would cause a failure even if the chassis was powered up at the time.
Can you think of any other hardware, software or environmental changes that occured when the problem first arose?
Brandon G
Precision DC Hardware Engineer
