11-06-2005 09:20 AM
11-07-2005 04:59 PM
Naveen,
It doesn't appear that there is an IVI call for self-calibration. It may not be part of the IVI standard, but I haven't been able to look into that. One thing to consider, though, is that you don't want to run the self-cal repeatedly. At the most, you'd want to do it once a day at the most. So if this code is running more often than that, you could write a separate program with just the NI-DMM calls to self-calibrate the board and run that once a week or so. Is that a possibility?
Tyler S.
