09-24-2018 01:56 AM
Hello Sir,
We want to measure the "Printed Circuit Board" connector pin resistance.
Below are the requirement.
Please suggest a suitable cDAQ device that can measure the above said resistance.
10-10-2018 10:34 AM - edited 10-10-2018 10:38 AM
Sound like a end of line test.
Needed accuracy?
thougths on task:
The high pin or channel count target to a switched system ,
low impedance measurement to a 4 wire measurement
in conjunction with contacting* and TC voltages: AC measurement or at least swapped polarity
*) the real hardware task (I think) for EOL test a pin-PCB impedance in 4 wire
max possible current ?
suggested hardware:
switch martix (solid state?)
bipolar current source (or more switching), stable (traceable?) or one or more reference resistors
2 diff voltage channels
No cDAQ high channel switch matrix 😞
No cDAQ with a low ohm range (400Ohm ) 😞
PXI-System with a SMU?
