Digital Multimeters (DMMs) and Precision DC Sources
PXI-4072 Capacitance measurement error
Hello everyone.
Is it possible to show not only the measured capacîtance value but also the range of uncertaintly of the specific measurement?
(3,953 Views)
Hi MicTek,
The  'Uncertainty' of the measurement could be represented in terms of  the gain and offset error.
This is shown in the specs for the device as (%of reading + % of range): http://www.ni.com/pdf/manuals/376167b.pdf#page=9
If you wanted to do this programmatically, you could implement a small LUT of the spec, read from the Range property as the reference point (% of Range), have the user implement their expected value (% of Reading), and do a little bit of math on the back end to display a measurement certainty range to the user.
Here's a rough guide on how you could implement the math:
http://zone.ni.com/reference/en-XX/help/370384V-01/dmm/accuracy/
Best Regards.
ChristophersonJ
(3,939 Views)
Hi ChristophersonJ !
Thanks for your answer. The links were helpful. With that it is possible to calculate the accuracy according to the device specifications.
What I wondered is, if it is possible to extract a value for the accuracy of the specific measured capacitance value from the FFT peak analysis (e.g. the peak width) performed in background.
(3,934 Views)
