Digital Multimeters (DMMs) and Precision DC Sources
PXI-4060 Crashes computer when ever a meausement is done then does memory dump.
That's great Brian! Especially that it was such an easy fix for you. Good luck with the rest of your application, and let me know if you have any other problems with your set up. Have a great day!
Logan S.
Message 11 of 13
(4,549 Views)
To Brian,
Is your data aquisition time very slow? I'm experiencing the same problem as you described and it seems to be fixed by setting the reset pin to false on DMM Initialize.
To Logan,
I am upgrading my instrument drivers and LabView, but the data aquisition time turned out to be three times slower than the my old setup.  I am using a PXI-1052 with doing synchronous triggering with a DMM4060 and a SCXI-1128.  Here are my old and new driver and LabView versions:
Old: LabView 6i, NI-DAQ 6.9.3f3, NI-Switch 1.6, NI-DMM 1.6, MAX 2.2,
Message 12 of 13
(4,357 Views)
sorry, I accidently hit a wrong button and submitted...Smiley Tongue
to continue:
Old: LabView 6i, NI-DAQ 6.9.3f3, NI-Switch 1.6, NI-DMM 1.6, MAX 2.2, VISA 2.5.2
New: LabView 7.1, NI-DAQmx 8.0, Traditional DAQ 7.4.1, NI-Switch 3.0, NI-DMM 2.5, MAX 4.0, VISA 3.4.1 (these are the latest as I'm writing this)
Thanks to Brian finding out about the reset pin.
Also, I couldn't use the test VIs Logan put up.  It's missing Digits_to_AbsRes.vi, where can I find it?
Here is my email if any of you would like to contact me:   leon.y.su@dupont.com
Leon
Message 13 of 13
(4,355 Views)
