03-09-2010 09:42 AM
Can the PCI 4060 still be repaired? Is the software for the PCI 4065 compatable with the software for the PCI 4060?
03-10-2010 10:14 AM
As far as I can see the answer is yes, the PCI-4060 can still be repaired. You'll want to contact Customer Service (ni.com/contact) to make sure and to set up the repair. Are you seeing a particular problem that might be addressed on this forum?
The software is NI-DMM for all NI DMMs. One way to check compatibility is to go to the drivers & updates page (ni.com/updates) and search for "DMM". The latest version should be on top and when you click on it to go to its page, you should look in the readme for specifics. I recommend finding (Ctrl+F) all instances of "4060" and/or "4065" to read about any differences, as there are some (such as Vista support, naming, triggering, etc.).
I hope that helps.
03-10-2010 10:25 AM - edited 03-10-2010 10:26 AM
03-10-2010 11:49 AM
That was what I needed to know.
