If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Digital Multimeters (DMMs) and Precision DC Sources
PCI 4060
Can the PCI 4060 still be repaired?  Is the software for the PCI 4065 compatable with the software for the PCI 4060?
(7,827 Views)
As far as I can see the answer is yes, the PCI-4060 can still be repaired. You'll want to contact Customer Service (ni.com/contact) to make sure and to set up the repair. Are you seeing a particular problem that might be addressed on this forum?
The software is NI-DMM for all NI DMMs. One way to check compatibility is to go to the drivers & updates page (ni.com/updates) and search for "DMM". The latest version should be on top and when you click on it to go to its page, you should look in the readme for specifics. I recommend finding (Ctrl+F) all instances of "4060" and/or "4065" to read about any differences, as there are some (such as Vista support, naming, triggering, etc.).
I hope that helps.
Mark E.
Precision DC Product Support Engineer
(7,811 Views)
Message Edited by ManLongAtNI on 03-10-2010 10:26 AM
Glenn
(7,810 Views)
That was what I needed to know.
(7,797 Views)
