‎05-06-2022 01:11 PM
We commit to preserving NI-DCPower's binary compatibility. An existing application built against an old version of NI-DCPower will work with an updated NI-DCPower.
This is of course assuming the platform is still supported. For example, we dropped support for 32-bit OSes (not applications) some time ago. We no longer support Windows 7. Etc.
‎05-06-2022 01:45 PM
That is great, not all developers do that. What I was looking at was the LabView version compatibility charts.
Could you explain more about what those charts are indicating?
Since an old version of LabView is just an application the same as mine and thus should work with the newer drivers?
Are the chart just an indication of what versions you have done formal validation against?
‎05-06-2022 01:48 PM
LabVIEW VIs store source and object code in the same binary by default. You can open a LabVIEW N VI in LabVIEW N+1, but it will show a "dirty" dot because the VI gets re-compiled for the new version of LabVIEW and the object code is modified. For that reason, our drivers ship with 4 copies of the VIs for 4 versions of LabVIEW that are already compiled for each specific version of LabVIEW.
One thing you cannot do is open a VI saved in LabVIEW N+1 in LabVIEW N without going through the manual step of saving for previous.
Not that what I describe above is the current state of affairs and something that will be changing in the near future.
‎05-06-2022 01:54 PM
Excellent explanation. Thanks so much. This helps A LOT. I have been nervous for some time about our test application and the risk of instruments going obsolete and how we can add new instruments and still maintain backward compatibility with older testers. Your description helps out a lot.
‎05-06-2022 04:12 PM
@kirsch wrote:
0x7A78 is the subsystem ID for the PXIe-4139 (40W), a newer higher-powered version of the PXIe-4139. I am afraid your driver may be too old for it (assuming the board is OK of course).
From the NI-DCPower 20.5 readme
