Digital Multimeters (DMMs) and Precision DC Sources
NI4060 Repair
I am getting unusual bad readings with NI-4060 DMM. Basically I found its adding some offset value to all measurements and this offset is changing .
I would like to send it to repair
Could you please let me know the whom should I contact and the formal procedure. Also I would like to know the cost for the standard repair.
Thank You
Sarath
(6,746 Views)
Hello Sarath,
To get a product repaired we need to take the part number and the serial number from you and set up a return. Please could you call into the office on 01635 572410 and discuss the problem over the phone. We can then set up a return for you.
Many thanks,
Peter H.
Applications Engineer.
NIUK.
(6,742 Views)
