Digital Multimeters (DMMs) and Precision DC Sources
NI-DMM Soft Front Panel related
 i got a NI USB-4065 in my hand
And i want to use it to insted of the Oscilloscope to measure the Vote & record it.
But after i installed the Driver of the NI device,  I can't find the Software "NI-DMM Soft Front Panel"
how can i find software "NI-DMM Soft Front Panel", or what software & driver I need to install.
i'm a newbee here, if you know it pls. help me
thank a lot
(4,715 Views)
What version of NI-DMM did you install? Newer versions (18.0 and newer if recollection serves) install InstrumentStudio as a replacement for the NI-DMM Soft Front Panel.
Tobias
Principal Software Engineer
Driver Software
(4,676 Views)
hi,
NI-DMM 19.5 is installed , what's your suggestions, if it's better to install a old version NI-DMM
and also i can't find InstrumentStudio which you mentioned...
(4,654 Views)
hi, Tobias
thank you very much for you support
I've install InstrumentStudio, I will try it tomorrow, and i'm not sure if it support NI DMM-4065
and I just want to use NI DMM -4065 to measure the Voltage, SFP is much more useful.
so  do you know where can I download old version software for NI- DMM, I hope I can try it...
(4,646 Views)
You should install the latest version of NI-DMM. Open MAX (Measurement and Automation Explorer) and verify that the USB-4065 shows up in there. Select it and then press the "Test Panel" button.
Marcos Kirsch
Chief Software Engineer
NI Driver Software
(4,632 Views)
Accepted by topic author Peter*DMM
Thanks a lot , i will try!!!
(4,568 Views)
