02-15-2020 07:19 AM
i got a NI USB-4065 in my hand
And i want to use it to insted of the Oscilloscope to measure the Vote & record it.
But after i installed the Driver of the NI device, I can't find the Software "NI-DMM Soft Front Panel"
how can i find software "NI-DMM Soft Front Panel", or what software & driver I need to install.
i'm a newbee here, if you know it pls. help me
thank a lot
02-15-2020 09:57 PM
02-16-2020 11:30 AM
hi,
NI-DMM 19.5 is installed , what's your suggestions, if it's better to install a old version NI-DMM
and also i can't find InstrumentStudio which you mentioned...
02-16-2020 12:53 PM
hi, Tobias
thank you very much for you support
I've install InstrumentStudio, I will try it tomorrow, and i'm not sure if it support NI DMM-4065
and I just want to use NI DMM -4065 to measure the Voltage, SFP is much more useful.
so do you know where can I download old version software for NI- DMM, I hope I can try it...
02-17-2020 09:03 AM
You should install the latest version of NI-DMM. Open MAX (Measurement and Automation Explorer) and verify that the USB-4065 shows up in there. Select it and then press the "Test Panel" button.
02-23-2020 03:27 AM
Thanks a lot , i will try!!!
