I'm in trouble with my T&A system. After last weekend both my PXI-4070 DMMs are no longer 'active'. The last action I do remember is updating NI-SwitchExec to the most recent version.
I see both DMMs in MAX as 'PXI1Slot7' and '..8', both in tradDAQ and DAQmx. Both entries show device params like SN#, socket#, IRQ-level and so on. In tradDAQ I can even initiate a ressource test under 'properties', which tells me the device passed.
If I try to initiate a self test under DAQmx, I get error -88705: The specified device is not present or not active in the system. It may not be installed, unplugged or not correctly installed. Device: unknown device.
I even can not delete this device, neither when having it installed in the chass
is nor when having it uninstalled. Even a 'reset NIDAQmx configuration' or a temp renaming of the config3.mxs does not remove 'em.
BTW, the MAX config file config3.mxs is quite large (4.5MB).
Any hints rather than re-installing the whole system?
(Its quite complex: W2k, LV7, TS, IVI, 34 serial ports, GPIB, PXI-1010, 2 DMM4070, a 1129 switch matrix, a 1160 MUX, a 6508 and a 6711. There's a mySQL database running that is accessed from TS3. Took a very long time to get all working properly... )
Greetings from Germany!
Uwe Frenz
