Digital Multimeters (DMMs) and Precision DC Sources
Im getting EInvalidOp on DMM Read Function
Im getting a EInvalidOp when using NI-DMM 2.8 with a DMM PCIe-4065.
Currently we are using C++ BUilder Borland  6.0 with 2.8 library.
I can start the dmm with Dmm Init function and set the dmm to read resistance, but instead of getting an overrange I get the EInvalidOp.
(8,325 Views)
I forget to mention that I made an application to test the issue. With this application the error is Floating Point error.
(8,318 Views)
Hi and sorry for the inconvenience.
I'd like to point you to another forum thread that deals with a similar issue.
http://forums.ni.com/ni/board/message?board.id=250&message.id=31772&requireLogin=False
I hope this information gives you some insight.
PBear
NI RF
(8,301 Views)
I tried that thread information with no good results.
The problem is this one. We have DMM's 4070 working with this same function and driver, But is not working with 4065. Some at technical support sent me a Labwindows CVI program and it works fine.
I write a DLL as workaround in Labview to read the resistance and it is working. But I think there is something else not tested with the driver.
Thanks in advance,
Armando
(8,296 Views)
Hi Garcia,
While we do not official support our libraries under Borland C++ compiler, I'd like to point you to the following KnowledgeBase. This will show you how to turn off floating point exceptions. KB 3SJA58DR: Floating Point Exception When Calling Borland C++Builder or Delphi DLL or Executable
PBear
NI RF
(8,285 Views)
