Digital Multimeters (DMMs) and Precision DC Sources
How do I programmatically get ALL the devices in MAX and their aliases
I am designing an application where I need to verify before starting that all the hardware is present.  I have a variety of hardware required from DAQ, DIO, GPIB, USB, and DMM in my PXI chassis.  I am able to get all of the information except for the DMM.  In MAX 4.0(LV 7.1) it shows that my 4072(or 4070) is a DAQmx device but when I use the LabVIEW DAQmx property node DAQ System Daq devices it doesn't show the NI-DMM devices installed.
I need to programmatically determine what DMM device is installed and what it's alias is?  Can anyone tell me how to do this?
Attached is my attempt.
Mike T.
(10,077 Views)
For DAQ, DIO you can get the device names & their corresponding properties using NI-DAQmx. To get device  information of DMM, DIgitizers, Function Generators and HSDIO cards, use NI-ModInst driver. For getting device information of GPIB, use VISA functions.
For information about NI-ModInst refer to this knowledgebases linked below:
https://www.ni.com/docs/en-US/bundle/ni-modinst/page/nimodinst/overview.html
Kalyan
Kalyanramu Vemishetty
Automated Test Systems Engineer
(10,069 Views)
Is this also possible for Switch Executive Virtual Devices? I'd like to programatically (via LabVIEW) obtain a list of channel names against aliases.
Can it be done?
Many thanks.
Message Edited by kdmcmullan on 05-18-2006 07:15 AM
(9,976 Views)
In future, please post this question in switches to get a prompt reply. Currently, there isn't a way to programatically access switch executive virtual devices, channel names and aliases in LabVIEW. However, you can file a product suggestion for this feature using the following link:
https://forums.ni.com/t5/Idea-Exchange/ct-p/ideas
Kalyan
(9,948 Views)
Quick update using switch executive 2.1, you can get aliases and switch executive virtual device list. I am attaching an example code which demonstrates it. Please let me know if you have any further questions.
Kalyan
(9,940 Views)
