Digital Multimeters (DMMs) and Precision DC Sources
Getting Measure Function from Keithley SMU 2602
Need expert advise: I need to retrieve Keithley's Measure Function (which could only be Current or Voltage) by polling the instrument.
Usually it is done with a command similar to this: smua.command.
However I checked the reference guide and there is no such a command to get this info.
Any clues?
(6,281 Views)
You've posted to a board for NI DMM's - not a place for instrument specific questions. For this sort of question, you should be asking Keithley if you can't find the answer yourself in the manual.
(6,259 Views)
No idea why you would ask this in a NI forum instead of the keithley one.
Try:
print(smua.source.func)
(6,249 Views)
The forum is for NI DMMs and _Precision DC Sources_, which is the Keithley SMU. I've asked Keithley but have not gotted the response yet.
(6,240 Views)
See above.
Try:
This command prints the source function, not the measure function.
(6,237 Views)
No. It says 'Additional NI Product Boards'. A Keithley is not an NI Product.
(6,235 Views)
When I don't understand a particular device's syntax, I'll take a look at the LabVIEW instrument driver, if it exists (2602 located here), and see what they're doing.  Of course, a lot of these APIs just call into a DLL, but usually there's some helpful knowledge in the code.  Then you can just port the call over to an equivalent text-based syntax.  Hope this helps.
-John Sullivan
Problem Solver
(6,227 Views)
