‎02-08-2006 03:02 AM
‎02-09-2006 01:49 AM
Hi Olli
We use this instrument, I did not see many problems but saw some improvements in the driver.
What version of LabVIEW and driver are you using?
I proposed some changes to the driver that made the initialize clearer (less wrong error messages) and
proposed a better reading of data and interpretation of data.
Albert
‎02-09-2006 06:56 AM
‎02-09-2006 02:29 PM
Hi Olli
I always try to synchronise in hardware. Two independent timers always drift.
In this case I would trigger one with the bus and the other with the trigger out of the first.
Dependend on their location (close to each other or not). Otherwise I would try to find out if I could trigger them both fast after each other.
I did not use the ethernet (i suppose you used visa and not the old tcp/ip routines)
The software is quite new from keithley and I guess that ethernet is weakest.
I did not see this but was using only one instrument at the same time.
‎02-10-2006 09:34 AM
