Digital Multimeters (DMMs) and Precision DC Sources
Can my PXI 4070 DMM measure capacitors and transistors?
I want to use my PXI 4070 DMM to measure capacitors, resistors, diodes, zenor diodes and transistors, is this possible.
I basically want to run an In-circuit test on a piece of electronic circuitry.
(6,848 Views)
The 4072 will allow you to measure capacitance and this is not possible with the 4070.
Check out the following link for more info on diode measurements with the 4070:
Diode Measurements
Let me know your thoughts!
Stuart
Message Edited by S R on 07-12-2006 08:02 AM
(6,842 Views)
