Digital I/O
what is the different between 5620 and 5142.
HI,
i am trying to retreived the IQ information from 5142 card.  The output from the 5142 seem to is in term of series of bits. how to convert it to retreived only the IQ wavefrom as in 5620
Thanks you
(3,403 Views)
Accepted by topic author Weide
Hi Weide,
Are you already trying with any example VIs found in LabVIEW?? I found MT niScope IO.vi in NI Example Finder. I believe this is what you are looking for. Do ensure that you have Modulation Toolkit installed to run this vi.
Regards
Lee
(3,390 Views)
HI lee,
Thanks for the help.  one question here is it possible for me to use the NI 5660 in 5142?  or i have to create my own VI?
Regards
weide
(3,383 Views)
Hi Weide,
5660 is RF Vector Signal Analyzer and 5142 is Digitizer. The driver used for each device is different (NI-RFSA and NI-SCOPE respectively). Hence, the function used for each device is different. Therefore, vis written for 5660 cannot be used on 5142.
You can always go to NI Example Finder or our NI website to find any available vis for 5142. You can take them as a start and modify then to suit your application.
Hope this information is useful to you.
Thank you & Regards
Lee
Applications Engineer | NI ASEAN
(3,367 Views)
