Digital I/O
what is the accuracy for PXI-6511 and PXI-6512
what is the accuracy for PXI-6511 and PXI-6512 modules
(1,963 Views)
Accuracy of what? PXI-651x are DIO modules.
See NI 651x Specifications
https://tmesystems.net/
(1,929 Views)
HI
I need to know the accuracy of digital output signal while taking O/P 28V AND 0V from PXI 6512  and while providing digital input signal 28V AND 0V to PXI 6511.
(1,885 Views)
@JANASRI wrote:
HI
651x is Digital I/O device and accuracy is defined in terms of voltage thresholds for inputs and range of voltages for outputs. Accuracy for each of these threshold is not critical as these are not meant to be precision devices, if that concerns you, you need to reconsider the device.
Santhosh
Soliton Technologies
(1,872 Views)
I think I'm not following you with your request. But there isn't any accuracy here since the modules will read/write just a "High" or "Low", are you asking for the range or thresholds of those levels maybe?
Regards, Romell
(1,846 Views)
