Digital I/O
waveform size HSDIO 6552 2 lines ? 4 lines ? 128 lines ?
I m here to asking about my current problem, waveform size in HSDIO PXI-6552.
If the script is simple or the frequency is lower (10MHz or 20MHz), everything appeared fine.
generate wfm0
generate wfm1 subset (0,4)
wfm0 = a file with 2 lines
wfm1 = a file with 4 lines
This will definitely run smoothly. No problem. But when the script is 100times more complex ( or even 1XXXXX lines of command in script, for my project),
the waveform sizes (a waveform with 2 lines will surely caused u error) or subset length of 4 (eg. generate wfm1 subset (0,4)) will definitely cause u trouble too.
So, I really need some1 who know what happen with the waveform size to explain the image attached below.
for the example above, wfm0 should be at least 32 lines in a single file ? wfm1's subset length should be at least 32 lines ?
Can some1 explain how about when the command together with the trigger command like
" if scripttrigger0
generate wfm2"
the wfm2 must be at least 128 lines ?
Really look ahead for those who familiar with the waveform stuff for HSDIO 6552. I have redo the waveform generation tool over and over again, really desperated with how's is the requirement behind. System ran smooth in 20MHz doesn't mean that u will meet the requirement (script and waveform size) when it run at 100MHz.
Merry Xmas and Thanks for viewing this post, hope some1 here will show the correct way for me ..
Message Edited by engwei on 12-23-2008 10:41 AM
(3,260 Views)
Here I paste the common script and I label the minumum waveform size by a bracket.
Assume run on PXI-6552, at 100MHz
Please correct me If I m wrong. Thanks.
Common Scripting Use Cases
Single Waveform
script upOnly
  generate countUp(2)
end script
Generating Waveform Subsets
script upOnlySubset
  generate countUp(2) subset (0, 2)
end script
Generating Waveforms with Markers
script upOnlyWithMarkers
  generate countUp(2) marker0 (0, 20)
end script
Sequence of Multiple Waveforms
script upAllOnesDown
    generate countUp(2)
    generate allOnes(2)
    generate countDown(2)
end script
Finite Repetition (N Times)
script up3AllOnesDown
    generate countUp(2)
    repeat 3
        generate allOnes(32)
    end repeat
end script
    generate countUp(2)
    repeat 3
        generate wfm(32) subset (0, 32)
    end repeat
end script
Conditional Branching — If/Then Else
script upOnesOrDown
    generate countUp(2)
    if scripttrigger0 then
        generate allOnes(2)
    else
    end else
end script
Conditional Repetition — Repeat until Trigger
script upAllOnesUntilTrigDown
    generate countUp(2)
    repeat until scripttrigger0
    end repeat
end script
Message Edited by engwei on 12-28-2008 10:07 PM
(3,226 Views)
Continuous Generation — Repeat Forever
script upThenUpAndDownForever
    generate countUp(2)
    repeat forever
        generate countUpAndDown(32)
    end repeat
end script
    generate countUp(2)
    repeat forever
        generate countUpAndDown(32) subset (0, 32)
    end repeat
end script
Waiting for Triggers
script upWaitAllZerosDown
    generate countUp(2)
    wait until scripttrigger0
    generate allZeros(2)
end script
or
    generate countUp(2)
    clear scripttrigger0
end script
Finite Wait
script upWait32Down
    generate countUp(2)
    wait 32
end script
Stepping Through Multiple Waveforms
script stepThroughUpAllZerosDown
    repeat forever
        generate countUp(128) subset (0,128)
        generate allZeros(128)
        generate countDown(128)
    end repeat
end script
Bursting through Multiple Waveforms
script burstThroughUpDownThenZerosOnes
    repeat forever
            generate countUp(512)
            generate countDown(512) subset (0,512)
        end repeat
            generate allZeros(512)
            generate allOnes(512)
        end repeat
    end repeat
end script
*My assumption is (from try and failure experience) , subset length must be minimum length of the waveform sizes.
I need a confirmation, whether it is right or wrong. Please correct me. Thanks.
Message Edited by engwei on 12-28-2008 10:11 PM
(3,225 Views)
HellOooo .. Please leave some comment here if you have some idea about it. THanks.
(3,169 Views)
