Digital I/O
waveform chart and 2 digital signal
i need show 2 or more digital input signal from USB6008 in waveform chart, but every signal must have different offset, is it possible, thank you?
(5,381 Views)
That means you want to plot two curves to not the same coordinates, am I right? Or how do you mean different offset? Is it offset in X-axis or Y-axis?
Thanks for clarifying.
Jakub
NIEE AE
Jakub Prokeš
NIEE Aplications Engineer
(5,344 Views)
For example : first digital signal start on y-axis 0 (in log "0") and finish on y-axis 1 (in log "1") and second signal start on y-axis 2 (in log "0") and finish on y-axis 3 (in log "1"), do you understand me? Look for attachment, thank you very much.
(5,334 Views)
Accepted by topic author Koudy
Just add a constant offset to the second signal between the Boolean to (0,1) and the Bundle node.
Lynn
(5,327 Views)
Thank you guys !!
(5,323 Views)
