Digital I/O
using NIDAQmx with Matlab
Hi there,
I'm trying to create a digital output with Matlab. The output of the code doesn't report any errors, but there are no signals on any pins. Before running the programm, pins are set as hight, after running the programm, the lines of the channel, which has been created ('Dev1/port1/line0:7') are set as 'low'.  So I'm sure that the channel has been created, but I don't know whats going wrong, when I'm trying to WriteDigitalLines. Here's the code....anybody any clue?
clear
all
close
all
clear
global
if
~libisloaded('nicaiu') % checks if library is loaded
loadlibrary(
'nicaiu.dll', 'NIDAQmx.h', 'mfilename', 'temp')
end
DAQmx_Val_ChanForAllLines=int32(0);
autoStart = uint32(1);
timeout = double(10);
dataLayout = uint32(0);
% writeArray = [1,0,0,1,1,0,0,1];
read=libpointer(
'int32Ptr',0);
reserved=libpointer(
'uint32Ptr',[]);
numSampsPerChannelWritten=libpointer(
'int32Ptr',0);
numSampsPerChan=int32(0);
TaskLoad=0;
if
TaskLoad
taskh1=0;
calllib(
'nicaiu','DAQmxLoadTask','SpeakerSteuer',taskh1);
else
taskh1=libpointer(
'uint32Ptr',0);
taskname=
'SpeakerSteuer';
[TaskCreated TaskName CreatePointer]=calllib(
'nicaiu','DAQmxCreateTask',taskname,taskh1); % create Task taskh1
taskh1=libpointer(
'uint32Ptr',taskh1);
[ChanCreated lines nameToAssignToLines]=calllib(
'nicaiu','DAQmxCreateDOChan',get(taskh1,'Value'),'Dev1/port1/line0:7','',DAQmx_Val_ChanForAllLines)
%%int32 DAQmxCreateAIVoltageChan (TaskHandle taskHandle, const char physicalChannel[], const char nameToAssignToChannel[], int32 terminalConfig, float64 minVal, float64 maxVal, int32 units, const char customScaleName[]);
end
StartTask = calllib(
'nicaiu','DAQmxStartTask',get(taskh1,'Value'));
[WriteDigital Data SampsChan ReserPTR] = calllib(
'nicaiu','DAQmxWriteDigitalLines', get(taskh1,'Value'), numSampsPerChan, autoStart, timeout, uint32(0), uint8(255) , numSampsPerChannelWritten, reserved)
%[y,x,c,v]=calllib('lib', function, taskHandle, int32 numSampsPerChan,bool32 autoStart, float64 timeout, bool32 dataLayout, uInt8 writeArray[],int32 *sampsPerChanWritten, bool32 *reserved)
StopTask = calllib(
'nicaiu','DAQmxStopTask',get(taskh1,'Value'))
ClearTask =calllib(
'nicaiu','DAQmxClearTask',get(taskh1,'Value'))
% unloadlibrary 'nicaiu'; % unload library
(2,950 Views)
First of all, the digital output on multifunction daq hardware form national instruments is inverted per default. This means if you want all lines to be high, you have to set 0 instead of 255. You can change this behaivour in MAX, but the default is inverted logic.
Second, there are some things in your code that should be changed: If you want to do static IO (no timing) you should use the function DAQmxWriteDigitalScalarU32 instead of DAQmxWriteDigitalLines.   DAQmxWriteDigitalLines is meant to transfer arrays of data to the driver, for the case you are duing buffered generation.
If you want to use the function you must set the numSampsPerChannel to 1, not 0.
André
(2,927 Views)
Thanks a lot,
this post was really helpful, it works now.
When Using WriteDigitalLines I also tried to set numSampsPerChannel to 1, but it didn't work (200562: DAQmxErrorInvalidDigDataWrite).
So I used :
[WriteDigital ReserPTR] = calllib('nicaiu','DAQmxWriteDigitalScalarU32', get(taskh1,'Value'), autoStart, timeout, uint32(255), reserved)
as recommended to set all pins high (I'm using a PCI 6503 card, I don't know if the pins are inverted on other cards) and it works now.
biiiiiiiiiiiiig THX
(2,917 Views)
