03-20-2008 03:31 AM - edited 03-20-2008 03:34 AM
03-20-2008 06:25 AM - last edited on 02-19-2024 04:22 PM by migration-bot
See the Using Quadrature Encoders with the DAQ-STC chapter of this document for the proper wiring of the encoder with a Series E DAQ board.
PFI = Programmable Function Interface. See chapter 6 in the user manual of your card for more details.
03-20-2008 12:37 PM
Thanks for the pointer! This was very helpful.
Would you know how I can see the encoder output through our MATLAB+wincon+simulink setup? The simulink library has a model under the NI toolkit called the encoder input, but I am not seeing any results through that. Does the simulink model rely on this counter that gets updated with my encoder's feedback? Or will I need to play with something else to emulate this counter?
thanks again!
03-21-2008 11:53 AM - last edited on 02-19-2024 04:23 PM by migration-bot
Hello bobray,
There is an abundance of people on the NI forums with great knowledge about National Instruments hardware and software, but that is not true when it comes to MATLAB® and Simulink®. I know that National Instruments has several options when it comes to combining our hardware with this software.
I am not sure what option you are using when you say you are using the NI toolkit, but do you mean the Simulation Interface Toolkit? If you can provide more details about exactly which software you are using, then I will be better able to give you advice.
