07-20-2023 11:22 AM
Trying to use USB-6003 on ubuntu 22.04.2
1. install ni-daqmx using apt - reboot the OS
2. install midaqmx library for python using pip
3. make sure device is connected with dmesg command
sudo dmesg:
[ 1222.042703] usb 1-1.3.4: new full-speed USB device number 15 using ehci-pci
[ 1222.156832] usb 1-1.3.4: New USB device found, idVendor=3923, idProduct=76c6, bcdDevice= 1.00
[ 1222.156865] usb 1-1.3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1222.156883] usb 1-1.3.4: Product: USB-6003
[ 1222.156896] usb 1-1.3.4: Manufacturer: National Instruments
[ 1222.156910] usb 1-1.3.4: SerialNumber: XXXXXXXX
sudo apt -s install ni-daqmx
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
ni-daqmx is already the newest version (23.5.0.49389-0+f237).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
yet the device is not found
Python 3.10.6 (main, May 29 2023, 11:10:38) [GCC 11.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import nidaqmx
>>> system = nidaqmx.system.System.local()
>>> connected_devices = system.devices
>>> print(connected_devices.device_names)
07-20-2023 05:55 PM
USB-6003 is not supported on Linux Desktop. From NI Hardware and Software Operating System Compatibility:
07-21-2023 03:43 AM - edited 07-21-2023 03:45 AM
thank you for your reply,
I was aware of the page you mentioned.
this is what confused me
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019NhFSAU
07-21-2023 07:35 AM - edited 07-21-2023 07:37 AM
And the followed sentence states that
To my knowledge, the only supported USB devices are USB cDAQ-917x.
07-23-2023 03:01 AM
https://www.ni.com/en-il/shop/model/cdaq-9171.html is a chassis only.
making the solution much more expensive.
I'm new to NI devices. never thinking devices as such does not support Linux.
thanks again.
02-04-2024 04:58 AM
Hi, We have ubuntu 18.04 and arm64 processor in it. We have ni daq 9232, can you tell me whether we can work on that hardware using python. Means we are not getting the correct drivers and not getting whole installation. Means some packages are showing that NI package doesn't support arm64 architecture. We have another system with 20.04 and amd64 processor and installation of ni-daqmx seemed installed on it. But while running a python program it came with error saying libnalk.so or something is not installed. verify or something. Please help me with this topic
