Hello, Do you have a simple example of code which reproduces your issue? So that you can post it here and I will try to understand this behavior. Tell me also exactly what is your programming environment, driver version, and hardware used. Do you know the name of the function which generates the timeout error? Thanks in advance for all the details. Matthieu Gourssies National Instruments
