04-21-2009 12:41 PM
Im sending serial data from a PIC18 microcontroller to the PC com port. Im using a USB cable to do this by using a virtual port that emulates a COM port. I am expecting to graph the data since it is a patience's heart signal. My question is will I be able to calculate the heart rate in labVIEW. will I be able to display a warning when the signal goes below a threshold value? If so, are there any examples related to this ..
thanks
04-21-2009
12:48 PM
- last edited on
06-21-2026
10:45 AM
by
Content Cleaner
First, you posted to the wrong board. this has nothing to do with Digital I/O. There is a dedicated Life Sciences board. Second, these is an extremely popular question and you can find a wealth of information by searching for 'ecg'. Third, NI has a Biomedical Startup Kit. This is capable of acquiring signals with NI hardware but the analysis routines should work for you.
