03-12-2019 03:54 AM
Goodmorning,
I'm quite new in the NI community and it's the first time that I use a NI usb-6002.
I need to generate a PWM signal by using Labview to control an electric engine (it's an engine for drones application). Someone can help me to do this?
Thank you
03-13-2019 08:16 AM
from this thread it seems to me we can conclude the USB-6002 device is not suitable for generating PWM signals.
Kind regards,
Alessia
03-13-2019 11:15 AM
You can try "abusing" one of the analog outputs as a PWM by driving the output to a specific level (e.g. 5V) for a specified duration via daqMX. Another option is to use the daqMX counter/PWM VIs and see if they are compatible with your USB device. But for this kind of applications, I would generally recommend dedicated hardware, like cRIO or PXI
