Digital I/O
Reply
sample code for NI PCI-6518
Could anyone please provide me with a sample code to read the pins of NI PCI-6518 card. I want to read to perform a digital I/O functions.
Where can i find the circuit diagram of the connections?
Is the code for PCI-6518 and PCI-6519 , the same?
I am new to DAQmx, so thought of starting the work with a sample code.
Thanks in advance.
Regards
Grugh Mike
Success is Everything !!
(1,538 Views)
Re: sample code for NI PCI-6518
grugh:
The code for the 6518 and 6519 will be largely the same. I don't believe there are any device-specific examples, mainly because the general DAQmx Digital I/O examples all apply to the 6518.
The best place to find them is in the LabVIEW Example Finder. In LabVIEW, go to Help»Find Examples. Inside the example finder, browse to Hardware Input and Output»DAQmx and look in the Digital Generation, or Digital Measurements folders.
You can find the pinouts for the 6518 in the manual, here.
Hope that helps!
Caleb Harris
National Instruments | Mechanical Engineer | http://www.ni.com/support
(1,519 Views)
i could find the "read digital signals example", but am confused about how to write digital signals.
Could you please provide me with a combined example.
Regards
Grugh Mike
(1,488 Views)
There the basic examples called Write Digital Chan and Write Digital Port. What is confusing?
(1,485 Views)
