10-05-2010 06:16 AM
i HAve written this code in VB to simultaniously running two tasks 1.write to digital line 2. Generating pulse on Counter 0 PIN
its giving me error 200077 requested value is not supported value of this property
Option Explicit
Private taskHandle1 As Long
Private taskHandle2 As Long
Dim sampsPerChanWritten As Long
Dim data0(0 To 1) As Byte
Dim data1(0 To 1) As Byte
Private taskIsRunning1 As Boolean
Private taskIsRunning2 As Boolean
Private Sub Command1_Click()
StopTask
End Sub
Private Sub startCommandButton_Click()
data1(0) = 1
On Error GoTo ErrorHandler
startCommandButton.Enabled = False
DAQmxErrChk DAQmxWriteDigitalLines(taskHandle1, 1, True, 10#, DAQmx_Val_GroupByChannel, data1(0), sampsPerChanWritten, ByVal 0&)
taskIsRunning2 = False
DAQmxErrChk DAQmxCreateTask("", taskHandle2)
taskIsRunning2 = True
DAQmxErrChk DAQmxCreateCOPulseChanFreq(taskHandle2, "Dev1/ctr0", "coChannel", DAQmx_Val_FrequencyUnits2_Hz, 0, 0#, 2500, 0.5)
DAQmxErrChk DAQmxCfgImplicitTiming(taskHandle2, DAQmx_Val_AcquisitionType_ContSamps, 1000)
Exit Sub
ErrorHandler:
If taskIsRunning1 = True Then
DAQmxStopTask taskHandle1
DAQmxClearTask taskHandle1
taskIsRunning1 = False
End If
startCommandButton.Enabled = True
MsgBox "Error: " & Err.Number & " " & Err.Description, , "Error"
End Sub
Private Sub StopTask()
DAQmxErrChk DAQmxStopTask(taskHandle1)
DAQmxErrChk DAQmxClearTask(taskHandle1)
End Sub
Private Sub Form_Load()
data0(0) = 0
DAQmxErrChk DAQmxCreateTask("", taskHandle1)
DAQmxErrChk DAQmxCreateDOChan(taskHandle1, "Dev1/port0/line8:8", "", DAQmx_Val_ChanForAllLines)
DAQmxErrChk DAQmxStartTask(taskHandle1)
DAQmxErrChk DAQmxWriteDigitalLines(taskHandle1, 1, True, 10#, DAQmx_Val_GroupByChannel, data0(0), sampsPerChanWritten, ByVal 0&)
End Sub
Private Sub Form_Unload(Cancel As Integer)
StopTask
End If
End
End Sub
Can Any body help me with this code
