Digital I/O
"power on" states at PCI-6503 Card
i´ve got trouble with my PCI-6503 PCI Card. In the manual I read about the Jumper W1 to set the power-on state to high or low.
When I set the Jumper to HIGH and connect my voltmeter to pin 48 and 47 I get something about 5,17 V. That´s fine.... BUT, when I switch the Jumper to LOW, I get 4,7 V between the pins 48 and 47 ?????????
These pins are only for explanation, this result I recieve for all the IO-pins...
I also tried to set the Jumper to HIGH and to use a resistor for all the lines, but with this 7,1 KOhm resistor, shown in the manual, I get 1,6 V after switch on my computer.
maybe there is a hardware damage?
regards
dieter
(2,043 Views)
Hi Dieter,
This behavior is described in this KnowledgeBase entry:
http://digital.ni.com/public.nsf/allkb/5EB377C6A0C5C83F86256FBE00730E62
If you need to have the original behavior (with no bus hold), please contact NI support, referencing the KB above.
We apologize for the inconvenience.
Thank you,
Allen
(2,030 Views)
