Digital I/O
"Open Config Data VI" does not find "configuration file path" in LabView real-time 2022 (with cRIO-9040)
I'm an absolute beginner with LabView. I have to write a program that is going to run standalone on the cRIO and I want to read from some .ini file in the program.
Open Config Data VI trow this error
which means that it does not find the path. Which make sense because I look for I file in my computer, but the cRIO as something to do with Linux, right?
So I found this page: Working with File Paths on NI Real-Time Targets - NI, which should solve my problem but it doesn't.
What am I doing wrong?
Aris Monaco
(1,552 Views)
So what file path did you wire to the input? Please attach your code so that we can see what did you do wrong.
https://tmesystems.net/
(1,528 Views)
This is the .ini file
This is the path where I put the .ini: /C/Users/aris.monaco/OneDrive - *****/PRJ_WicklungsVerbackAnlage_WVA/03_Implementation/02_Software/03_LabView/Konstanten_v1.ini
And this is a test to try and read the code, but I get that error: Open/Create/Replace File in NI_LVConfig.lvlib:Load.vi->NI_LVConfig.lvlib:Open Config Data.vi->Main.vi<APPEND>
(1,521 Views)
Accepted by topic author ArisMonaco
I solved it. I needed to upload the .ini file on to the cRIO and use the path to there. For example /home/lvuser/text.ini.
(1,512 Views)
