I'm trying to use a phidget 8/8/8 interface with labview, but I can't see the device in measurement and automation explorer. I installed the phidget 21 driver package and can see the device with their program. I also tried to aquire signals with the DAQ assistant and was unable to see it there. Any suggestions?
You won’t be able to see your phidget kit in LabVIEW right away since it is not NI hardware. In order for you to interface it with LabVIEW, we would need to add it as a USB resource. Please follow this USB Instrument Control Tutorial to help you set it up. Let me know how this works.
Regards, Daniel REDS RF Systems Engineer
Help us grow. If a post solves your question, mark it as The Solution. If a post helps, give Kudos to it.
