06-11-2015 07:01 AM
I have inserted a PCI-DIO-96 in three different PCs riunning Windows XP. In all cases the Device Manager does not show resources allocated automatically to the card. It is recognised as being a "PCI card" but no further progress is possible - there is no data posted in the "properties" sections of the DM. Does this suggest that the card is faulty?
Do I understand the installation procedure correctly - resource address allocation should be automatic?
06-11-2015 07:11 AM
Did you install DAQmx? DAQmx is the driver for NI's DAQ boards.
06-11-2015 09:58 AM
No. I didn't think a driver is necessary for register-level software. Is DAQmx easy to find on this huge wesite? Thanks for your help.
06-11-2015 10:18 AM
06-11-2015 11:07 AM
There should have been a disc that was shipped with the DIO card that has DAQmx. If you do not have that, the latest version can be found here: NI-DAQmx 14.5.1
